Building a JD model 50 for Pulling
Daniel
09-07-2004 07:07:09
I am wanting to build the motor in my 50 for pulling. Can anyone tell me a good oversized piston that can be used in this application and how much over size can I go, and can the sleeves be removed for bigger pistons? Clooney, if you read this, I emailed you a couple questions on this subject
Ben.So.Tex
09-07-2004 08:27:49
 Re: Building a JD model 50 for Pulling in reply to Daniel, 09-07-2004 07:07:09
Daniel. I pull with my stock 50. it does good. never lost power just spun out. I have new tires on it now and hope it does better this year. Where are you from/ or where do you plan to pull. I plan on pulling in Hondo and New Braunfels Texas. Good luck Ben
G-MAN
09-07-2004 07:37:39
In addition to what buickanddeere said, the factory JD two-cylinder blocks do not have sleeves, they are parent-bore blocks.
buickanddeere
09-07-2004 07:19:30
The 520/530 stock makes as much power as a souped 50. The B is usually modified for the division II & III classes. It can get into lighter classes than the 50. The 50 pretty well has to pull in the 5000 and up classes. There are some Olivers in that weight range that can mix and match factory parts and make double the HP of any modified B/50. Everyone thinks HP is required for pulling and winning. It helps some on loose tracks but on clay not much. Concentrate on getting traction 1st. No use spinning out at mid track with 75 HP while someone else putts over the end of the track in creeper gear. Loose track use full tread 45 degree bar tires. Hard clay track use short tread bars with a 23 degree angle. The taller the tire out pulls a shorter, wider tire. Get the drawbar at max legal height, max legal weight, good tires, proper tire pressure, drawbar length/fore and aft balance. You will place in the top three regularly.
Mike Aylward
09-07-2004 10:14:06
 Re: Building a JD model 50 for Pulling in reply to buickanddeere, 09-07-2004 07:19:30
Glen, I agreed with everything you said except for the last part: "you will place in the top three regularly"..:-) If it were only that easy! Mike
