Piston Ring Grooves
Austin
09-07-2004 07:00:54
I have a 1939 D with High Altitude pistons. Everything on the piston is in great shape except for the first ring groove. The slide clearence is way above tolerance on both the pistons on the first groove. I herd that maybe I could have a machine shop cut the groove big enough for two rings to fit in there. Sence they are high altitude pistons they have a taller head and could accomidate another ring. Any Ideas?
Thanks!
Clooney
09-07-2004 08:10:54
 Re: Piston Ring Grooves in reply to Austin , 09-07-2004 07:00:54
Austin, I have found many D's with the top piston ring groove worn like that..
You have a few different ways of handling that problem..
First- is to stick the pistons in a lathe [or have it done] then buy custom made rings to fit the new groove width..
Next- would be to do as above but buy ring backers first [thin ring spacing shims] then cut the ring grooves to match the new ring + backer width..
Next- would be to use double rings as you suggest..
If for parade & light use only you can also leave the top ring out..
I usually buy the ring backers from Otto�s pistons rings then put the pistons in a lathe & cut the grooves to match the new ring + backer.. 2 rings will work but double ring thickness can bring on other problems.. If you do go the double ring route use thin rings for the second ring, as thin as possible]..
You might want to talk to Otto�s Gas Engine Works [410-398-7340 ] as they have all kinds of cures for that worn top ring groove..
[email protected]
