318 or 360 Chrysler engine needed a.s.a.p.
Pat Cruise
09-06-2004 19:17:05
I need a 318 or 360 Chrysler engine for my 87 Dodge Ram.I am not able to haul my tractors without this truck.I live in eastern Kansas and can pick it up if it is close to the Kansas City area.Many Thanks,Pat
Jake
09-06-2004 20:06:17
 Re: 318 or 360 Chrysler engine needed a.s.a.p. in reply to Pat Cruise, 09-06-2004 19:17:05
I can't help on the engine, but if you do not already know... there are some differences you need to be aware of if you are replacing a 318 with a 360 or vise versa.
One... the 318 is an internally balanced engine. the 360 is an externally balanced engine. The vibration damper is different between the two engines and the 360 uses a torque converter that has two balance weights welded on it. The 318 does not use these balance weights. If it is a manual transmission then the flywheel may be balance differently but I have not experience with that and you will have to ask someone else.
Two.... one engine mount is different between the 318 and 360. I forget which side is different.
