Deere 2020 3 pt Hitch problems
Gary on the hil
09-06-2004 18:13:26
I have a JD2020 LU model. When I lower the 3pt hitch it does not stay lowered. The lever will return to the raise position on it's own and raise whatever implement I'm using. I tried going through the adjustment procedure however I couldn't find the Negative Stop screw which should have either been on the right rear of the transmission case or below and to the right of the PTO. Therefore this was not adjusted. I did a Neutral Range Adjustment and a Load Control Arm Adjustment. Hydralic fluid level is ok. What am i missing or what should I do to correct this.
david val
09-07-2004 01:20:49
 Re: Deere 2020 3 pt Hitch problems in reply to Gary on the hill, 09-06-2004 18:13:26
the rockshaft lever has a 'brake' that pulls lever twards quadrant with spring pressure that creates friction. this friction overcomes the tendency of the lever to move twards the 'raise' position. this brake is actually a set of washers and wavy spring washers on the lever's pin (or bolt). if you have a bolt there, (and the correct washers set) you may adjust friction by tightening the bolt/nut. if it's a pin (most likely), you probably have to replace the spring washers.
david
