Hydrualic loader plumbing
Lincoln
09-06-2004 17:51:45
I have a 1966 3020 with a 148 loader on it. The loader hydraulics are plugging in to the two hydraulic outlets. I'd rather have a joy stich or two lever type control but not sure where to run the hydraulic supply from. Any help would be appreciated.
CNJ152
09-15-2004 20:17:17
 Re: Hydrualic loader plumbing in reply to Lincoln, 09-06-2004 17:51:45
We fixed a 4020 where the hydraulics were plumbed to the selective control pressure and return was returned to the transmission.
Call or e-mail if interested. Phone 256-845-0757.
Thanks,
Neil
Dave Sherburne, NY
09-09-2004 19:10:35
You can mount the new valve and hook it to one of the outlets, and tie the lever to operate it .
or JD used to have a block which mounted between the actual valve body {the part you plug the hoses into}and the piece it is bolted to on the tractor. I have seen one where some elbows were change to tees on a hydraulic line but I think that was on the one with the valve levers on the
dash. If you had a manual for the loader JD
usuallly gives the options. For instance my 2640
changes an elbow to a tee for pressure, and the return line goes to the filter housing. send me an e-mail, I may have the manual.
