4230 hydro dash light blinking
KENTER
09-06-2004 17:12:39
I CANT FIGURE OUT WHY MY HYDRO/TRANS LIGHT KEEPS BLINKING IT JUST STARTED IT. DO YOU THINK ITS THE FLUID I USED? IT WASNT JD BRAND BUT IT MET ITS REQUIREMENTS.CAN SOMEONE OFFER ME ANY ADVICE?
DON
09-06-2004 18:11:07
 Re: 4230 hydro dash light blinking in reply to KENTER, 09-06-2004 17:12:39
ONE POSSIBILITY IS (ASSUMEING YOUR HYD. ARE WORKING OK) IS IF YOU FILLED OUT OF A BARREL AND PUMPED OFF THE BOTTOM, YOU COULD HAVE GOT ALL THE BEARIUM THAT SETTLED OUT AND PLUGGED THE FILTER. I WOULD CHANGE THE FILTER AND TRY IT. IF NOT CHECK TRANS. PUMP PRESSURE. HOPE THIS HELPS . DON
cannonball
09-07-2004 04:58:36
 Re: 4230 hydro dash light blinking in reply to DON, 09-06-2004 18:11:07
make sure that the wire has not wore a bare spot, mine did..they are close to the clutch rod...have nice day may god bless
