JD 60 Hydralics
daniel gillespi
09-06-2004 06:54:55
anybody know off hand what the hydralic oilfilter number if it has one is so I can replace it. The hydlaics on the 3pt hitch wont raise so i was told to drain the system and replace the filter. It has a power troll system.
Clooney
09-07-2004 04:44:53
 Re: JD 60 Hydralics in reply to daniel gillespie, 09-06-2004 06:54:55
Daniel, those old Deere Power-Trol units don't use a filter..
Give us a little more information on your Power-Trol non operational problem & we can help you..
*Was it working, then just quit?
*Has it ever worked since you have owned it?
*Can you hear the engine labor when at low RPM�s when you hold the Power-Trol lever all the way in either direction?
*Is the Power-Trol oil level up to the test cock level?
*Is the P/T pump engaged [up on the governor if live power equipped].. PTO must be engaged on the non live power tractor..
Let us know�..
[email protected]
buickanddeere
09-06-2004 08:52:45
Also check if the valving selected for the remote outlets or for the rockshaft. It's in the operators manual how to swap it over.
Mike M
09-06-2004 08:11:19
No filter used on those. Check to make sure that the pump is engaged,a little handle down under the left side of the dash.Do not engage with the engine running or you could break something.
