Cracked head on a 'D'
dwm
09-05-2004 21:13:38
While having the head on our 48 'D' in for a valve job and magnaflux, a crack was found between #2 intake and exhaust valves. Does anyone know how common this is--does the crack open between the combustion chamber and water jacket? Any experience with welding? Probably time for another head? Any input appreciated.
Earl S.
09-06-2004 19:09:13
 Re: Cracked head on a 'D' in reply to dwm, 09-05-2004 21:13:38
This repair is called stiching. It works very well if done properly.Find a machine shop that does crack repair.Most of the younger guys want to buy new heads. Which is Ok on the later pass. cars. Here is one of the best method of repair.www.locknstich.com. tapered plug that screws in and special thread to seal.Let us know if you need help. Where do you live? Earl In Illinois
dwm
09-07-2004 18:51:43
 Re: Cracked head on a 'D' in reply to Earl S., 09-06-2004 19:09:13
The D is in south central Indiana. I had not heard of this method of crack repair. The machine shop my brother went to originally suggested welding, but we were not sure that was a good idea with cast. We'll look into it. Thanks for the responses.
Wayne in Tn.
09-06-2004 10:58:05
DWM, your machinist probably would have mentioned it to you, if he had the ability to repair it. My machinist has an old timer that can repair those cracks by "pinning" them. He drills holes and drives in some type of metal pins, then grinds it down. He can even repair cracks across the valve seats. He will drill the first hole, pin it, then drill the next hole, centering it at the edge of the first pin, then on and on until the crack is filled. I have never had a problem with this type of repair.
