4020 gas carb
Dieselbear
02-04-2004 16:36:55
Can anyone give me the numbers of this carb , so I know if I have the rite one? Thanks, Glenn
Mike M
02-05-2004 06:06:20
 Re: 4020 gas carb in reply to Dieselbear, 02-04-2004 16:36:55
I think it depends on what year the tractor is to get the (correct) number. I will also tell you that I have a 4020 gas that had the correct number carb on it,one of those all aluminum marvel
scheblers and I finally listened to all the people that told me that they were junk and put a cast iron Zenith on it.The Zenith's will make them run alot better through all speed ranges.I also know that I do not even have one for a 4020 it is for a 3010 or 3020 I got it cheap and it works good after a rebuild.These engines have the same bore and stroke just two more cyl's and they all can't draw air at the same time.It seems to work really good.
Dieselbear
02-05-2004 15:55:49
 Re: Re: 4020 gas carb in reply to Mike M, 02-05-2004 06:06:20
Thanks, Mike. I am having the same problem, except on a G-1000 gas. the alum. carb is junk!!! Was told that the castiron carb. off a 4020 or a 1800/1850 oliver would work. They all used that alum. junk one. But Moline never changed to the Bendix/zenith. I just wanted to make sure I was getting the rite one. Glenn
Mike M
02-06-2004 05:17:44
 Re: Re: Re: 4020 gas carb in reply to Dieselbear, 02-05-2004 15:55:49
I see that the aftermarket is selling new carbs.
for the JD's they may have a listing on yours if you want to spend that much. $400 +or -. I have seen the Zeniths on e-bay. I don't think that you will notice any differance in a 3020 vers
a 4020 carb as I have not yet. Mine does have a adjustable load mixture screw make sure you get an adjustable one.
