Nicholas, as Im sure youre aware, any voltage drops across either resistor depends on the points being CLOSED (so theres current flow through the resistors) and making a good ground contact without having to go through any carbon or burned pitted contact surfaces. The purpose of the external ballast is to reduce the voltage of a 12 volt battery down to around 6 volts same as if it had a 6 volt battery, so that reading of 12 volts AFTER the external first ballast makes me think its EITHER almost a short circuit ORRRRR RR the points arent making good contact. However, the reading of 5.6 volts after the second ballast tells me the points must be closed and drawing current and theres 6.4 volts (12 - 5.6) dropped across the internal ballast. If that first ballast is shorted and NOT dropping any voltage, then youre running the Wico at twice its intended input voltage which means twice the coil current and twice the current the points must switch which is more duty on the condensor which can overheat the coil and the condensor wouldnt last as long. I would measure the ohms on the external ballast to see if its near a short circuit cuz that may be your problem. I would suspect it to be low, maybe in the 0.5 to 1.5 ohms range BUT NOT NEAR ZERO. I think Duane may have the exact value its supposed to be, but if its not dropping any voltage, it must be near zero??? and if so ITS BAD OR SHORTED. Yes, more input voltage on a transformer yields more output voltage, b ut I think youre problem may be the external ballast is shorted cuz if you get the Wico inout down yo 6 then the coil voltahe wil be lowered and theres less current being switched and less current spike havign to be absorbed by the condensor affecting its life. What does Duane think????? You have the value of that external ballast??? John T [email protected]
