Randy, one of the bad things that can happen is that BOTH the eccentric bushing and the bore it fits into become so worn that even a new factory eccentric bushing still has excess slop/play and a new one oversized one may have to be fabricated or the bore shimmed. As far as adjustments that "may" cure the problem, proceed as follows: 1) BOTH wheels need to have their bearigns adjusted properly (the pre load) on the spindles, use matched tires, and have both aired proper and equal. 2) If theres any excess fore n aft horizontal end play in the steering shaft, see if you can take some of it up by removing the front steering shaft bearign end cap (2 horizontal bolts) and removing some shim/gaskets if necessary so the shaft doesnt have excess fore n aft end play. 3) If the wheels bearings n tires are adjusted and you took out any horizontal end play and she still wobbles, its time to look at the sector to worm gear clearance. 4) Remove the top front sheet metal nose piece crown medallion,,,,,remove the 4 bolts/screws on top the steerign pedestal cover..... ..clean out the grase n gunk,,,,, ,, locate and remove the bottom vetical locking set screw in the base of one of the eccentric bushings half moon locators,,,,, ,,have the front end jacked up just a tad to remove pressure,,,,, ,, use a bar or driver etc (after set/lock screw removed) to rotate the eccentric bushing to move the sector gear over closer to the worm gear. CAUTION NOTE Since most worm n sector gear wear is in the straight ahead position, you cant set the sector too close to the worm there or else she will be too tight n bind out at the turn ends. What this procedure does is to rotate the offset ecentric bushing which moves the sector gear closer against the worm, and then replace the bototm vertical lock screw/bolt back into a new half moom locking locator. I grease the worm n sector then refill the steerign box with a witches brew of grease and 140 or 250 weight gear oil, and even add some STP or Lucas oil additive (to thicken it) and then button her back up. Its possible the bore the eccentric bushing fits into is worn out, but start with adjustign the wheel bearings,,,,, air both matched tires the same,,,,, ,,,remove any excess horizontal fore n aft steering shaft end play,,,,, ,,then if necessary rotate the eccentric bushign to move the secgtor closer to the worm and you may cure the problem, NO WARRANTY LOL Let us know, Good luck n God Bless John T
