2020 looses electric power
Mel
09-05-2004 14:26:54
My brother-in-law has a 2020 gas that looses all electric power every once in awhile. It might start right up and run for 5 or 10 minutes and then just die. After a short time-5 minutes or so- it will start right up again and then do the same thing. He says there is no power to the starter when this happens and the indicator lights go off. He tried a new battery but that did not help. Any ideas as to what is happening ?
Bob
09-05-2004 22:03:34
 Re: 2020 looses electric power in reply to Mel, 09-05-2004 14:26:54
There is a circuit breaker up under the dash somewhere. Very likely, there is a damaged (bare) wire somewhere that is vibrating against metal and intermittantly shorting out, tripping the breaker. The other likely possibilites are a defective breaker, or loose/dirty connections on the breaker that are causing it to heat up and trip.
