Bigfoot, A few thoughts on your problem - do the replacement wires have a copper core? - They should have - don't use the carbon core wires with a magneto. Are the new plugs Champion W-20? I'm not sure what a p-20 plug might be. Anyway, some folks have better luck with Autolite 3077 long nose plugs, so you might try those.However, the clue seems to be the stumbling/hesitation/stalling when the throttle is opened. If you advance the throttle slowly, does it work ok? Does it do ok under a load? If the answer to these questions are both yes, then one possibility is the small holes in the carburetor nozzle are plugged. When the engine throttle is advanced rapidly, the engine needs additional fuel to accelerate, and additional fuel is drawn in through these small holes during acceleration. When the engine returns to idle, the space around the nozzle ("acceleration well") refills. The solution to that is pulling the nozzle and cleaning it. Another possibility is a weak coil, which does not have sufficient output to provide a spark during the higher compression pressures associated with acceleration, and could also cause the occasional miss of the engine. Since I don't know what magneto you have, in general if you remove the magneto cap to access the coil, using an ohmmeter you should measure between 5000 and 8000 ohms or so from the high voltage button on the coil to ground. If you provide the make and model of the magneto, we can provide some additional info.
