6400 radio
terry garber
09-05-2004 09:53:37
I have a 6400 with a cab. the antenna base is loose. does anyone know how it is mounted to cab roof. looks as if I may have to take out the paddding on the inside to get to it. thanks for any advice.
Francisco
04-20-2005 05:55:44
 Re: 6400 radio in reply to terry garber, 09-05-2004 09:53:37
All you have to do is remove the top from the cab. There are two large bolts midline with the roof and multiple smaller bolts all around the edge. The wires from the lights will have to be disconnected temporarily to give you enough room. To get a visual Idea of what you need to do, check out John Deere parts on line at John Deere home page etc. Good luck, Francisco
huig
09-16-2004 13:20:17
you have to remove the cab that is only a few bolts on the front and two big ones on top
