1520 PTO
mike in MD
09-05-2004 09:12:49
I have problems engaging my PTO. With no load or a light load (like a post hole digger), the lever goes ahead no problem and the PTO starts running. With a heavier load, the lever goes halfway, then sticks and sounds like grinding gears. I have to turn off the tractor, engage the lever and start it back up with the lever engaged. Any ideas what's wrong here?
Bob
09-05-2004 09:29:17
 Re: 1520 PTO in reply to mike in MD, 09-05-2004 09:12:49
Apparently, you have the "continuous running" PTO.
The last half of travel when the foot clutch is depressed releases the PTO clutch, and you then shift the PTO lever to the "engaged" position.
You then let up slowly on the foot clutch until the "PTO" driven implement comes up to speed.
If everything is properly adjusted in the clutch, at this point you should still be able to shift the tractor into gear, release the clutch the rest of the way, and drive off.
When the clutch is again depressed about half way, the tractor should stop moving. When you depress the clutch the rest of the way, the PTO driven equipment should be disconnected from the engine, and begin to slow down.
Is this how you have been operating the tractor, depressing the clutch before shifting the PTO lever into gear? If there is still grinding with the clutch pedal fully depressed, and after waiting a few seconds, you may have a stuck or mis-adjusted PTO clutch at the engine flywheel.
