1948 b over heating
dexter
09-04-2004 16:07:08
i overhauled a 1948 johndeere b i went .045 over on the pistons and all that stuff anyway i pulled with it a couple of times and the temp. only goes up to like 140 but a couple of weeks ago i plowed with it and it went up to 210-215 and so i stopped and idled it down and left it sit like that for a lil bit but when i took off again i was in 2nd gear and about 1/2 throttle and it went right back up there.. There is no water pump in it but i was wounderin if i should put on in it or if there is something else i could do?? any information will be apreached thank you
Jim Nauert
09-05-2004 18:13:11
 Re: 1948 b over heating in reply to dexter, 09-04-2004 16:07:08
My 51 B likes to run hot when i plow with it . It also has .45 over pistons it will run a little cooler with just plain water in it. But it has never boiled over with a 50/50 mix. I say just use her and enjoy it these tractors where made to run day in and day out under some harsh conditions. Don't worry it can take it as long as you don't abuse it too much.
Pappy
09-04-2004 22:33:07
If it doesn't boil over, let 'er run. One thing I noticed. You said you were running it at only half throttle. This could be a problem. If you are pulling a load at half throttle, you are lugging the engine and this will cause higher temperatures. Run it up the full throttle when pulling a load. Your operators manual will tell you this. Slow engine speed means slow fan speed, thus more heat build up.
Will P
09-04-2004 21:18:31
My 43B will run 220-230 with 50/50 water and antifreeze working. If I run straight water it will only go to 200 working. To run tractor fuel of the days past, you had to have these tractors over 190. There is less wear on an engine running hotter than colder. I don"t have any problems with the coolant temp, that you have been running.
Will P
Mike M
09-04-2004 18:17:23
That thermo siphon system has to be near boiling to circulate when you are working hard.
This may be normal unless you are seeing steam or boiling over at radiator cap.
Russ
09-05-2004 16:50:56
 Re: 1948 b over heating in reply to Mike M, 09-04-2004 18:17:23
1948 John Deere B. That is the same JD that I had for several years. Make sure the 50/50 coolant is topped off properly, make sure engine oil is up to the proper level, start plowing in second at full throttle and stop when it is dark or you run out of gas. If your kicking up big rocks or boulers too often find another field. Nothing runs like a Deere.
