Fuel needle jumped peg
TS Johnson
02-04-2004 15:33:23
It's a 1999 or 2000 5205. It seems they all have that same instument panel on them. Is it possible to touch the fuel guage needle by removing the top plexi shield?? Somehow the needle jumped over the stop peg and is stuck behind it.Thanks,T
RayP(MI)
02-05-2004 18:20:10
 Re: Fuel needle jumped peg in reply to TS Johnson, 02-04-2004 15:33:23
Might try removing the guage, tapping a hole in the side of the case 1/16", or so. Then reach in with a fine wire, and see if you can reposition the needle. Solder or epoxy the hole shut, reinstall! Good luck - Like the idea of a magnet - for first approach.
Leon R
02-04-2004 15:51:04
If that needle is steel maybe a strong magnet might be enough to lift it over the pin. Just a thought as I am not familiar with those instrument clusters.
