6030 hydraulics
5020Chris
09-04-2004 13:50:23
Hi, can anyone tell me when the 3 point is in depth control should the rear arms move in direct relation the position of the quadrant control lever ? When mine is in depth control and you pull the control lever rearwards nothing happens until the lever is half way back and then the arms just go all the way to the top. Is this correct or can someone tell me how to adjust the settings ? Thanks in advance,
Chris.
Glen in TX
09-05-2004 02:22:57
 Re: 6030 hydraulics in reply to 5020Chris, 09-04-2004 13:50:23
Hi Chris, I was hoping you had found a owners manual for it. I'll send some pages from my OM to explain more. In D or depth control it will set it down to where you put quadrant lever or can move the quadrant lever all the way forward and it will allow it to float. In L or load it will raise or lower depending on ground contour. In LD1 or LD2 which are load and depth it will hold it more even in ground and LD1 will give more reponse to the load depth than LD2.
