Help on Identifying JD Tractors....
RobD
09-04-2004 05:31:39
Hi all, I was referred to your forum as a great resource for tractors. I am looking for some help on identifying some JD tractors and implements in a picture that I sell. I have built a collection of wallpaper borders that are automotive related and then take them to car shows to sell. By request I added a couple tractor related borders as well, including one that is John Deere themed. I think it has been available for a few years so I imagine most of you guys have seen it already. I have a link to a picture of it here:
Link
Ben.So.Tex
09-05-2004 07:24:01
 Re: Help on Identifying JD Tractors.... in reply to RobD, 09-04-2004 05:31:39
No sterringwheel/battery box on the new generation ,the G stacks are wrong, one rear tire on backwards, and a few more. I was given this print as a gift, So heads up....
Bill-NNY
09-04-2004 20:41:22
My guess for the steel wheeled tractors are from left to right:
Fordson
McCormick-Deering (IHC) 10-20 or 15-30
John Deere D
On the John deere paper, The large frame 46/48 series tractor would be from the 40 series with dual head lights minus the front end light bar ( but hey! it just wall paper). Syncro range 3020 or 4020 with the long handle PTO lever. 9000 series combine and a GH (by the open flywheel)
just my 2 cents
Bill
krk
09-04-2004 19:17:45
The border states "The above represents the repeated section of the border." There are three tractors in the border. The far left and far right partial views of tractors are the same tractor. This border represents John Deere's evolution in tractors because it shows a 2 cylinder (Popping Johnny), a Generation I 10 or 20 series, and a Generation II 30, 40, 50 series. The model of the tractor can be narrowed down to 2 models each but it is difficult to be 100% positive for a single model. As CMB posted -the intercooler leaves only a 46 or a 48 model.
CMB
09-04-2004 10:45:07
I'll try to help, if I can. The partial view at left is from the 1961-1972 era, probably a 3010/ 3020, or 4010/4020. The large tractor on the grain cart is newer- after '72 & with the engine showing an intercooler would probably be a 4630-40-50, or a 4840-50. The high crop, second from right is a "GH", & totally out of place in a corn harvesting scene. The last one on the right is probably a 3020 or 4020, as it has the "New Generation" style seat,& the PTO lever on the right side.
Jon C -Florida
09-04-2004 13:22:40
 Re: Help on Identifying JD Tractors.... in reply to CMB, 09-04-2004 10:45:07
CMB - Is the "GH" a "G" high crop? Doesn't the G and A have 8 horizontal grille openings and the B have 7? Also I think the G has the exhaust and intake stacks side by side and the A and B in front and back. The 7 (or 6?) grilles and front and back stacks is why I was sort of thinking it could be a "B".
Hard to tell.
CLW
09-04-2004 15:21:02
 Re: Help on Identifying JD Tractors.... in reply to Jon C -Florida, 09-04-2004 13:22:40
Jon C, you are correct in everything except they didn't make a B HI-CROP. They made a BWH but it was different than the A & G. This one is a "G". Look close and you will see the stacks ARE side by side.
CLW
RobD
09-04-2004 18:33:41
 Re: Thanks guys... in reply to CLW, 09-04-2004 15:21:02
I appreciate the prompt & helpful responses. I see a lot of these 'unlicensed' designs tend to have hybrids, which is why identification has been difficult so far. I'll gather all your responses and try to adjust my description accordingly.
Did anyone want to take a shot at the mystery steel wheeled tractors? Or should I post that kind of question in a different forum (if so, let me know which one)
Regards,
Rob
Jerryh
09-04-2004 23:00:09
 Re: Thanks guys... in reply to RobD, 09-04-2004 18:33:41
I don't know what kind those are but I saw Mr. Douglas on one just about like it.
Jon C -Florida
09-04-2004 10:09:46
Well I will take the first crack at the two on the right, and hopefully several others will refine my guess.
The one all the way to the right, that only shows a portion of it, could be a "730" or "830" made around 1958 to 1961.
The next one just to the left of that one, looks like it could be a 1947 to 1952 wide front end, high crop late styled "B", if such a thing was made.
As the the newer ones to further left, someone else will have to take a stab at those.
2 Cylinder
09-04-2004 10:05:00
Might be able to if you had a little bigger photo.
