4030/4020/4230
Skybow
09-03-2004 20:17:30
There's a big consignment auction this weekend. Need no want to upgrade from my 3010 gas to a bit bigger diesel. They have 4030's, 4020's, and 4230's listed. as well as a 2640 W/loader. I am avery interested but have heard about the problems some JD have with pitted sleeves due to the coolant. Is there a sign to look for to see if these engines may be bad or do I have to tear down the engine to get the real story. I'd rather not buy a new toy and then have to tell the "boss" that I need to spend a ton of bucks to get it running. They also have a AC6070 and 3 white 2-105's. Any and all opinions are appreciated.
Jim@concordfarms
09-04-2004 07:01:39
 Re: 4030/4020/4230 in reply to Skybow, 09-03-2004 20:17:30
My 4400 JD combine with the 329 diesel (same engine as in the 4030 tractor) had to be overhauled at 700 hours due to a sleeve that was pitted thru. Several years later, I overhauled a 4430 JD tractor with the 404 engine, and at 8000 hours the sleeves were in great shape. My own two cents is that JD owners that use JD coolant conditioner experience a lot less cooling system related engine problems. Jim.
steveii
09-03-2004 20:26:17
Yes there bit of it.. with the pitted sleeves due to the coolant getting in the oil. to check that out lose the oil plug and open it slow.. DONT TAKE PLUG OUT, just get it lose and hold the plug in till you see a drop of oil if you dont see the coolant then it"s fine.. the old sleeves has one O ring line, I think there are new sleeves with two rings.. My 71 4000 needs a job done. but it"s holding when I put seal in the coolant.
sometime I"d lose the other plugs to check.
