4020 clutch job
J.A.
09-03-2004 18:38:55
OK, I'm going to try to finish up the clutch job on my 4020 D this weekend. It came apart easy enough, but now I have some questions about putting it back together. First, I just installed the PTO operating bearing and the throw-out bearing, but I'm not sure if I got them seated properly. Is there an easy way to tell, or does it even matter? Next, I've got a brand new complete expensive clutch assembly from the dealer and a resurfaced flywheel. Will I need to make any ajustments to the clutch fingers? I can get the special tool if I need it. Lastly, how on earth am I supposed to line up the splines on the clutch disks and shafts as I roll the thing back together? Is there anything else I need to lookout for?
msb
09-03-2004 22:03:45
 Re: 4020 clutch job in reply to J.A., 09-03-2004 18:38:55
Yes, you need to readjust the fingers.Do it with the dummy shaft installed while setting the pto fingers.You can remove the shaft when setting the clutch finger height.Take a couple of large screwdrivers and wedge the other 2 PTO fingers tight when adjusting the 3rd one.ETC,ETC. Be very careful when rolling the tractor back together that you don't mess up,the seal on the input shaft.If you use care in measuring and getting the two parts perfectly parallel then they usually roll together fairly easily.You may have to use a large screwdriver to turn the flywheen to get it to mesh up.DON"T FORCE IT with the bolts.If it doesn't go ,measure again and get it perfect.( Doggone uneven floor!)Eyeballing the dowel pins will help if you line them up.You can use a comealong to aid in pulling it together if you don't get carried away with force.(Watch those oil lines.lol) I just use a brass hammer to install the bearings.Tap them and they should bottom out.
steveii
09-03-2004 20:30:52
to line them up you need a dummy shaft to put in it to line it up that what I know about. but I dont know about those bearings. hope there are others can tell you.
