GDL, if shes wired correct and theres no shorted wires but the ammeter discharges n the Gen heats up when the tractors off, the VR"s Cutout Relay may be stuck closed. WIRING A 4 WIRE VR BAT terminal is wired up to the ammeters load (NOT to battery) terminal and should always read hot battery voltage. FLD on VR wires to Gens Field post LOAD on VR wires up to the switch for lights n ignition BAT input power. ARM (or GEN) on VR wires to Gens Armature post, its often off on one side or the bottom all by itslef. To see if a stuck VR cutout relay is the cause, see if the discharge stops when you unhook the wire from the ARM terminal on the VR to the Gens Armature post??? If so, it must be stuck. If it still discharges even with that wire unhooked, next see if unhooking the wire to the VR"s BAT terminal makes it stop??? If so there must be an internal VR short or an external wiring short causing the problem instead of a stuck relay in the VR. ANOTHER "MOTOR" TEST is to reconnect all the other wires but leave the VR"s BAT terminal disconencted,,,,, ,,,,remove the belt,,,,, and see if the Gen spins as a DC motor when you hook the hot wire to the VR"s BAT terminal. If so, again, the vR"s cutout relay must be stuck closed. She was originally positive ground and if the VR is really pos ground suitable??? there shouldnt be any polarity problems. SUMMARY: Check the Gen to VR wiring,,,,, ,insure no shorted wires,,,,, ,,,try unhooking the wire from GEN or ARM on VR to Gens Armature post (if discharge stops, the relay must be closed),,,,, ,,,if still discharges, unhook the wire to BAT on the VR and if it stops then, look for an internal or external short problem. Insure good grounds on BOTH the Gen and VR. Post back any questions and your results John T
