Changing 3020 Hydraulic coupler
Lincoln
09-03-2004 14:01:29
How big of a job is it to change the coupler between the motor and hydraulic pump? Mine is ratteling, should I change the whole thing as a unit or put new bushings in it. It on a 1966 3020 gas by the way. Thanks
RICKMAN
09-07-2004 18:56:14
 Re: Changing 3020 Hydraulic coupler in reply to Lincoln, 09-03-2004 14:01:29
I have a 69" 4020 that is doing the same thing . I bought the tractor last month, he told me about the noise said it had been that way for years . Seems like to me it gets louder at times, more than others . I think I will change mine out also . Let me know how you turn out?
S. Conner
09-03-2004 20:33:22
I't's an easy job to replace that coupling. Just remove the two nuts and bolts. The two halves come off and then you can see the bushings. If the bushings are worn so bad that there has been metal to metal contact for very long, it's best to change all the parts. Last time I bought this whole thing it was about $80. Also remove the tube on the pump shaft and check the splines in the tube for wear. Piece of cake.
