Broken Fan Bracket, WHY?
AGR538
09-03-2004 12:36:21
My friend has a 60. The front bracket for the fan shaft has broken twice. He replace the first with a new one and it has broken again. What could be causing this problem? Thanks in advance for any replies.
DON
09-04-2004 10:16:51
 Re: Broken Fan Bracket, WHY? in reply to AGR538, 09-03-2004 12:36:21
The fan bracket breaks because parts;"AB3314R, D399R, A4039R have worn out and let the fan come off centercauseing the fan to shake because it is not centered. Look at the sides of AB3314R part and you will see the wear. hope this helps don
DON
09-04-2004 10:16:25
DON
09-04-2004 10:16:08
Mike M
09-03-2004 18:20:19
Don"t no why yours broke,but most of those supports had shims under them from the factory to align them. Alot of times they get removed when a water pump is replaced. Could be a bad fan or bearings you might try to put a level on the main case and level the fan tube to match it can"t hurt.
G-MAN
09-03-2004 13:38:48
On of the ears on my 60 fan bracket is broken off, too. I couldn"t tell you why. Possibly 50 years of vibration at a weak spot in the bracket where it"s bent to sit flat.
ebbsspeed
09-03-2004 14:22:00
 Re: Broken Fan Bracket, WHY? in reply to G-MAN, 09-03-2004 13:38:48
Fan out of balance or a bent blade causing excess vibration?
