52- b noisey/ grinding noise in pto
tugboat tim
02-04-2004 14:45:56
my b runs like a top but when I engauge the pto an awfull grinding noise is heard. I have already taken the short piece of shaft out the back with the bearing but the noise was still there when I engauged the pto. What should be the next plan of attack Thanks tim
Clooney
02-04-2004 16:00:33
 Re: 52- b noisey/ grinding noise in pto in reply to tugboat tim, 02-04-2004 14:45:56
Tim, that's a difficult question to answer.. I guess the easiest is to pull the trans top cover & look down in the trans & see if the PTO gears are fully engaging..
~Other than that you will just have to work your way through it..
~It might make it easier to listen for & find the problem if you put the trans in neutral then spin the clutch pulley with a V belt & electric motor.. At least that should remove the engine noise from the PTO noise..
[email protected]
