55 ABH Plow Tail Wheel 3.50-12
Tyler-MO
09-03-2004 07:23:57
I am in need of a new or new old stock Plow tail wheel size 3.50-12". I know that there are 4.00-12" new tires available, however I would like to find the original size. If you have any idea for sources of these tires please pass the info along.
Bob Collins
09-03-2004 07:58:39
 Re: 55 ABH Plow Tail Wheel 3.50-12 in reply to Tyler-MO, 09-03-2004 07:23:57
If you want the original size, you should use the 4.00x12 that is what the parts book specifies. I think Miller tire has that one available.
David Nemeth
09-04-2004 19:09:03
 Re: 55 ABH Plow Tail Wheel 3.50-12 in reply to Bob Collins, 09-03-2004 07:58:39
A few years ago, the rear tire on my 55-A went bad and the rim was bad also. I was plowing for my neighbor and I needed to fix it fast. I had one of those doughnut tires and wheels from a Ford Tempo that they expect you to use when you get a flat. I used the old wheel for a pattern and drilled new mounting holes to make it fit. It worked and looked so well that it is still on the plow today.
