49 A ignition timing
wheels
09-03-2004 04:51:23
I have a 49 A with a Delco distributor. It has a Petronix electronic ignition. It also has a Power Block with 180 lbs. of compression on both cylinders. I have noticed that most manuals say 26 deg. BTDC. At what RPM? I have tried many different settings with not much difference noticed. Used for fun and light antique pulling. Any help appreciated.
Clooney
09-03-2004 07:59:53
 Re: 49 A ignition timing in reply to wheels, 09-03-2004 04:51:23
Wheels, the max timing advance you can run depends on many variables like engine RPM, cam duration & cam timing, fuel type used, induction system used, engine temperature, humidity, combustion chamber shape, combustion flame travel, spark plug gap & type, etc.. I guess what I�m saying here is only your tractor will know what the best timing advance is for it..
25�-26� is probably a good safe place to run it at.. Much less than that you will probably be giving up some power. Depending on your fuel used & total engine set-up you MIGHT be able to run a little more..
The best way I have found to set the timing on a modified tractor engine for max power is to get the tractor hot & belt it up to a dyno.. Then with it pulling a load at the RPM�s you want to tune it at play with both the spark advance & carb load needle [one can effect the other for max power]..
With that Delco dist. You probably should also play with the distributor weights & weight springs as you might easily be able to run more spark advance at a lower engine RPM but keep the total high RPM advance lower to help there..
My suggestion would be to get your tractor on a dyno & or talk to a puller that is running a similar set up as yours & see what he is running for both total advance & for distributor weights & springs..
[email protected]
John T
09-03-2004 06:49:48
Wheels, Congratulations, you got some SERIOUS compression figures workin there. With those a high energy solid state ignition can sure help in the spark energy and higher necessary firing voltages plus higher octane fuel necessary to prevent pre ignition. Did you couple that switch with a high performance coil????? ?? At high compression and exotic fuels etc I STRONGLY ADVISE IT. While a stock coil will still perform somewhat betetr with a soild state switch, to get the most bag for the buck from it, you need to couple it with a high performance coil and usually a wider plug gap and get a higher energy wider fatter hotter arc or more surface area to better ignite the fuel under high compressions.
That 26 BTDC should be at or near max RPM but sorry, I have no specs or data on that ignition etc to give you any exact answer at what RPM, hopefully, some of the other gents have such data n specs. I would try in the range of 25 to 35 BTDC (26 may be a tad on the slow side depending on your RPM) at its MAX RPM and see what happens. Unless youre running MUCH faster than stock RPM, you probably arent gonna gain too much (a dyno would tell) by too far advanced timing and if too fast, youre gonna start loosing in performance. Its when you start running those high compressions at extreme HIGH RPM"s when the timing advance curve becomes more critical, even if your RPM was say 1500 I dont see too much excess advance needed (while still some) so I would start at 25 to 35 BTDC at max RPM and load her up n go from there.
Do you have access to a dyno?? Let us know and my guess is that 25 to 35 BTDC at MAX RPM should get you close.
Good Luck, God Bless, Please pray for n support our troops.
John T
