Kyle, yep, if you had hold of the wire on a GOOD HOT MAG and she fired, it ought to give you a pretty good jolt. If not, you have to determine the cause, so here is a systematic process to use. If its a Wico C or X Mag??? the points gap to 0.015 on high cam open position, are yours n what mag you have??? FIRST: A common problem for weak mag sparks is burned or pitted or mis gapped or gray oxide coated points, you may wanna first take a look at them and replace if badly burned or pitted or carboned up, or even (if not too bad or maybe just oxide coated) clean/polish/file the contact points n re gap n see if she sparks then??? While in there, check the cap n rotor for carbon tracks or cracks or crud or moisture and you need to have good wire core NOT carbon core suppressor type plug wires !!!!! !!!! I have seen many not run but a simple non abrasive cleaning (like a shop cloth to remove oxide) or light file the points n gap if needed cures the weak or no spark problem !!!!! !!!! Its also possible the points spring or wires to the points (to coil and condensor) are shorted, so check that !!! If the points n cap n rotor appear okay (or you cleaned n gapped them) but still no spark and theres no shorted wires to the points or the points spring isnt shorted, see below:
PRELIMINARY: If the mag happens to have a kill wire or a side out kill button/push switch or even just the side stud out with no wire or switch IT CAN HAPPEN THE WIRES OR THAT STUD GETS GROUNDED (pass through insulator sleeve bad/broke) and that KILLS THE SPARK. Be sure no wire to it or the stud itslef or any wires inside it to the points ARE NOT SHORTED/GROUNDED 1) If you have the plugs removed for easy cranking and turn the flywheel, is the mag making a good loud sharp SNAP ??? If its a non reduction drive gear mag like a Wico Model C or X, that would happen each 180 of flywheel revolution. At crank speeds, regardless what type mag, she cant produce a good spark unless she makes that good loud SNAP, cuz thats made by a good working strong (NOT weak) spring wind n trip assembly. If the spring or wind n trip assembly were broke or weak or never engaging, like when the trip dogs are stuck or corroded, and dont extend to wind the spring, she cant spark at crank speeds, although she could possibly make a good spark at over approx. 250 RPM like if you pull started it. SEE IF N WHEN N HOW LOUD SHE SNAPS N WHAT MAG YOU HAVE N POST BACK !!!!! !!!!! !!!!! ! 2) If she never snaps, you might wanna loosen the mags mounts so its not so tight into the governor n see if it does (try an extra gasket), but if still not, you can remove it and manually rotate the rear coupler CCW facing it and see if the trip dogs extend out to catch then wind n trip a strong tight spring. Its possible the trip dogs may be stuck or corroded in which case a good clean n lube may fix the problem. Its also possible the spring may be weak or broke but it MUST extend n wind n trip against strong spring pressure n SNAP loud to produce a good spark aT crank speeds. 3) IF SHES MAKING A GOOD LOUD SHARP SNAP (you gotta get that first) then have the plug wires off the plugs but within 1/8 inch from the tractor steel and see if when she snaps a good hot BLUE and NOT a faint thin wimpy yellow spark jumps the gap (would be every other snap per plug wire if a Wico C or X). If it does, then attach a plug and have its side grounded and see if a good blue spark jumps the plug gap??? If not but the wires alone do, get a new plug, especially if old ones burned or fouled, n see what happens. 4) To test for a mag spark independant of any wires or plugs whatsoever,,,,, ,insert a wire or paper clip etc into a mag cap tower with the other end to within 1/8 inch from the mags metal side case and crank her n see if when she snaps a spark ever jumps that gap. On a Wico C or X that would be every other snap. 5) If a good snap but still no spark via a wire out the cap towers, remove the cap(s) and (possible but depends on what mag you have???) find the coils side output button/terminal and install a wire or paper clip etc from the mags metal side to within 1/8 inch from the coils high voltage output button/terminal AND TURN THE FLYWHEEL AND EACH MAG SNAP A GOOD BLUE SPARK OUGHT TO JUMP THAT GAP. If so there BUT NOT out the cap towers when the cap(s) are installed, its a cap or rotor or contactor problem. On the Wico mags, make sure the lil spring contactor makes good contact to the coils output button/terminal and the rotor tip. Its different on a Wico C or X, but you get the idea and a spring contactor has to get the spark from the coil to the rotor and its possibe where the coil fires BUT NOT the cap terminals, that springy contactor isnt correct n in place to contact the coil or rotor tip. 6) If a good snap n good gapped points but still no spark EVEN DIRECT OFF THE COILS BUTTON/TERMINAL, then it could be a weak or bad (maybe shorted) condensor or a bad coil or exces rust on the rotor or laminations or a wirign short to the points or condensor wiring. SUMMARY, check the points for gap and replace if badly burned or pitted or try n clean or file if not too bad,,,,, ,,,,,make sure she SNAPS loud n sharp,,,,, ,,If not, loosen or remove the mag and examine for the trip dogs extendign out n windign then tripping the spring,,,,, ,,check for a good BLUE spark out the cap towers via a wire to the side metal case then for a spark at the plugs or plug wires,,,,, ,,if none remove the cap(s) n check for spark direct out the coils output button/terminal via a wire to case and within 1/8 inch from coil,,,,, ,,if not check the poinyts n condensor and for any wire shorts to points or kill switch studs etc. START WITH GOOD NEW PLUGS, IF FOULED THEY ALONE CAN BE THE WHOLE PROBLEM, NEXT LIKELY CULPRIT IS OXIDE COATED OR BURNED OR PITTED OR CARBONED OR MIS GAPPED POINTS TRY THE CHEAP SIMPLE EASY THIGNS FIRST LIKE PLUGS N POINTS N INSURE THE CAPS SPRINGY CONTACTOR IS IN PLACE AND REMEMBER FIRST SHES GOTTA MAKE THE GOOD LOUD SNAP AND IF NOT CHECK THE TRIP DOGS FOR EXTENDIGN OUT N WINDING THE SPRING N CLEAN N LUBE IF NOT N RETRY. Post back the mag you have and your findings n any questions. Hopefully, others can add more to this and/or offer more tips n opinions. Let me know Good luck, God Bless, please pray for n support our troops John T Nordhoff in Indiana [email protected]
