1020 Leaks Hydr. Fluid from Steering Wheel!
EWB
09-02-2004 10:54:50
Halfway done cutting hay and fluid started gushing out from just below the steering wheel. This is a 1967 1020 Diesel. I have a mechanic coming over next rainy day but would appreciate any advice on what the problem is likely to be and how much the fix might cost.
david val
09-03-2004 06:10:54
 Re: 1020 Leaks Hydr. Fluid from Steering Wheel! in reply to EWB, 09-02-2004 10:54:50
if it's power steering, probably the thin 'o' rings that seal the valves are shot.
david
ewb
09-03-2004 06:28:32
 Re: 1020 Leaks Hydr. Fluid from Steering Wheel! in reply to david val, 09-03-2004 06:10:54
Any idea how much that is going to cost to fix?
