Compression ratio's
Geewhiz
09-02-2004 09:37:40
Where or what is the volume per cylinder in a 1950 stock John Deere "G" tractor. I need this to figure the compression ratio and more so to figure new ratio"s as I mill the head and or back of the block.
lynn
09-02-2004 16:51:02
 Re: Compression ratio's in reply to Geewhiz, 09-02-2004 09:37:40
Geewhiz..stock cubic inches is 206.25 per cylinder..compression is roughly 3.9..this figures to 71.1 cubic inches above the piston when it is atdc..total volume abdc is is 277.35 cubic inches..you cannot grind enough off to make a very big difference..for example .250 inch off the head will give you around 4.2:1..lynn
Geewhiz
09-02-2004 17:59:25
 Re: Compression ratio's in reply to lynn, 09-02-2004 16:51:02
Would you please show me how you figured that?
Thanks, Geewhiz
lynn
09-03-2004 17:51:57
 Re: Compression ratio's in reply to Geewhiz, 09-02-2004 17:59:25
Geewhiz..will use the comprssion Duane said the G's have..take 4.2 and subract 1 from that number and divide this into the cylinder cubic inches.. 4.2-1=3.2.. 206.25 divided by 3.2 = 64.45 cubic inches when piston is atdc..lynn
Duane Larson
09-02-2004 16:42:44
Geewhiz,
JD Field Service Bulletin 167 (2/15/50) gives the compression ratio as 4.20:1 for a G>13000.
Geewhiz
09-02-2004 18:05:51
 Re: Compression ratio's in reply to Duane Larson, 09-02-2004 16:42:44
Where do I find these Field Service Bullitins?
Thanks, Geewhiz
Duane Larson
09-02-2004 18:14:45
 Re: Compression ratio's in reply to Geewhiz, 09-02-2004 18:05:51
Geewhiz,
It took a number of years and dollars, but I have put together a complete set from September 1935 through October 1962 (about the last mention of 2-cylinder tractors). They show up sometimes on eBay. Two-Cylinder Club is printing some of them in their magazine, and Green Magazine also features info from them each month.
If you are interested in FSBs, provide your email address and I will contact you.
Geewhiz
09-02-2004 18:56:25
 Re: Compression ratio's in reply to Duane Larson, 09-02-2004 18:14:45
Duane- My e-mail address [email protected]
Thanks, Geewhiz
buickanddeere
09-02-2004 11:59:50
Compression pressure/cylinder pressure is a result of mechanical compression ratio, cam timing and volumetric efficiency. Depending on the octane of the fuel used,rpm range and cam timing depends on the compression ratio you want. Those tractors will knock at compression ratios that an automotive engine runs fine on.
Carl
09-02-2004 10:45:32
The displacement of a "G" is 412.5 cubic inches, so that would be 206.25 cubic inches per cylinder. The compression ratio is a comparison between the volume of the cylinder and combustion chamber with the piston at bottom dead center, divided by the volume of the cylinder and combustion chamber with the piston at top dead center, so the volume of the combustion chamber and the cylinder with the piston at top dead center must also be taken into consideration.
Geewhiz
09-02-2004 12:18:32
 Re: Compression ratio's in reply to Carl, 09-02-2004 10:45:32
The volume of the cylinder is what I need to know without taking apart the engine to measure for myself. I hope someone knows these numbers for a stock "G" engine.
buickanddeere
09-02-2004 13:12:49
 Re: Compression ratio's in reply to Geewhiz, 09-02-2004 12:18:32
pi x radius of the bore squared x stroke length.
Geewhiz
09-02-2004 15:02:59
 Re: Compression ratio's in reply to buickanddeere, 09-02-2004 13:12:49
I've got that formula, but what I don't have is the volume of the cylinder and head. I am trying to get a rough idea of these numbers without taking the engine apart.
AcE
09-05-2004 00:45:24
 Re: Compression ratio's in reply to Geewhiz, 09-02-2004 15:02:59
If you dont know what the bore and stroke, and other concrete numbers. AND you dont want to have to pull it apart... Build yourself a WET SPIROMETER That will give you a rough number of what the displacement is. And stick a compression gauge in the plugs
You should beable to find a ratio that will work. And you need to figure in a % of lost pressure and displacement. IT WILL BE ROUGH
but it can be done without tearing it down
