1946 John Deere B - Power Lift
Mark Trachy
09-02-2004 08:32:59
I am considering buying a John Deere Model B from a farmer down the road. The serial number on it indicates that it is a 1946. The tractor seems to be pretty much complete, and the engine spins easily but doesn"t start since it is missing the distributor cap and the spark plug wires are broken. The tractor has the Power-Lift option, and I was wondering, since I want to use the tractor for snow blowing, tilling, etc., if the Power-Lift system could be swapped for a Powr-Trol system, and if so where would I be able to buy a Powr-Trol system and about how m uch would it cost. The farmer is asking $1200.00 Canadian. (I don"t know if that is a good price). Thanks in advance.
Clooney
09-02-2004 09:32:55
 Re: 1946 John Deere B - Power Lift in reply to Mark Trachy, 09-02-2004 08:32:59
Mark, you can easily swap the Power-Lift for a Power-Trol just get the tractor side studs with the Power-Trol & it will bolt right on..
As far as Power-Trol or tractor cost? That I won�t comment on as I don�t comment of price or cost of tractors or equipment [the price won�t be too awful bad though as those Power-Trol�s are plentiful..
On the �B� & your comment �Quote: �I want to use the tractor for snow blowing, tilling, etc��I think you will find that �B� isn�t well suited to running either a snow blower or tiller as it doesn�t have a live PTO & the ground speeds won�t be good in reverse with the PTO spinning fast enough to operate a snow blower.. For both tiller & snow blower you will much better off with a later tractor that has a live PTO & an engine that allows better ground speed at PTO RPM�s..
[email protected]
