8450 HEAD GASKET
DON
02-04-2004 12:10:07
REPLACED THE HEAD GASKET A YEAR AGO AND NOW 400 HOURS LATER IT HAS BLOWED AT NO. 6 CYLINDER TO EX. SIDE. THE HEAD BOLTS WERE REPLACED AND TORQUED TO SPEC. IS THIS COMMON (I HEAR IT IS) WITH THIS TRACTOR? I THINK I WILL USE THE OLD TORQUE METHOD AND NEW B0LTS.WHAT DO YOU THINK? THE ENGINE HAS ABT. 2500 HRS.
Chad S (from illinois)
02-05-2004 20:19:03
 Re: 8450 HEAD GASKET in reply to DON, 02-04-2004 12:10:07
I know two people that had 8650's and they always had trouble with them. One in particular had to change a head gasket every spring. I dont know how simillar the engins are between a 84 and an 8650 but i just thought i'd share
G-MAN
02-06-2004 07:29:32
 Re: Re: 8450 HEAD GASKET in reply to Chad S (from illinois), 02-05-2004 20:19:03
The 8650 uses the 6619 engine, and the 8450 uses the 6466. Two completely different animals.
WTW
02-05-2004 07:14:06
Don, I have been putting heads down on John Deere engines for over 25 years and in that period of time I have had one fail and yes it was a four-wheel drive tractor (8430). This happened when Deere was experimenting with alterative materials for head gaskets in the late 1980's. A newer and different head gasket was furnished and this same tractor never failed a gasket again. Take the information that JDGNUT has shared with you and follow it to the "T". There is one more thing I do that is not in any Deere instruction. After tapping the holes, wipe down the previously cleaned head and block surfaces with lacquer thinner or something similar to remove all oil residue from head and block mating surfaces. Install head Gasket dry. Install all 26 head bolts "DRY" and torque to 75 ft-lb in sequence. Then remove (one bolt at a time) in the torque sequence and oil and re-torque to 75 ft. lbs. After all 26 bolts have been oiled and re-torque finish torque sequence as instructed in the manual. This process prevents oil from oiled bolts from creeping out into gasket and head / block surfaces. It takes a little more time but so does doing the job twice. I can promise you one thing and that is: If the tractor failed the gasket with the new process and it was properly preformed I will guarantee it will the old way too. Good Luck, Dave W.
DON
02-04-2004 19:24:13
Thanks guys , I forgot to mention that the head was planed and the cyl. height is .002 above the block and sleeves seem to be square with the block, holes were tapped & cleaned , bolts were oiled on both ends. The new torque ,twist off the bolt torque method was used for the bolts. I just cant go with that new torque method , I think that is why the gasket failed as you can see where it pulled and streched it .The gasket set was fresh from Deere as will be this one and another set of bolts. Stock fuel setting as the pump and nozzles were run also. very flusterating. If it don't hold this time a Kinzy refresher course is probably in order.
G-MAN
02-05-2004 07:39:15
 Re: Re: 8450 HEAD GASKET in reply to DON, 02-04-2004 19:24:13
If the gasket was damaged in the process of torquing the head, it's likely that the wrong torque sequence was used. Check the instructions carefully this time. There are a number of different torques used depending on the markings on the heads of the cap screws. I've never done the 75 lb. ft. dry torque/removal/oiled torque WTW mentioned, but if it works for him that's okay. I've put heads on 4960s pulling 260 horsepower on the dyno, which is probably in the neighborhood of 300 flywheel horse, and haven't had one blow out when properly installed and torqued. Your liner protrusion spec sounds fine, but make sure you have the liner clamped down with an H-bar and bolts torqued to around 50 lb. ft. when you check protrusion. If everything else is good, I'm betting that the proper torques weren't used last time the head gasket was replaced. How accurate is your torque wrench?
buickanddeere
02-04-2004 13:33:46
Run a bottom tap in the block threads to be certain. Cam assembly lub works best for lubing threads and under the bolt head if torqueing lubed. Make certain the cylinder head surface under the bolt head isn't galled.
G-MAN
02-04-2004 15:45:09
 Re: Re: 8450 HEAD GASKET in reply to buickanddeere , 02-04-2004 13:33:46
I use an old head bolt with slots cut in the threads to chase the holes. Works good with a cordless impact, as you can use a socket on them, and you don't remove any more material from the threads - just clean the existing ones. I squirt them full of Deere Electrical Contact Cleaner, run the bolt up and down a couple of times, and blow them out with compressed air. You can hit all 26 holes in a matter of a few minutes that way.
G-MAN
02-04-2004 13:32:14
The head's been off my grandpa's 8450 at least twice that I know of, and it's still under 5000 hours at stock fuel delivery. It's been planed both times and will need replaced if it ever blows again. JDGnut is right about everything he said. Make sure your liner protrusion is correct. If it's too high OR too low, it can lead to head gasket sealing problems. Chase out the bolt holes well, install the new-style gasket, make sure the head is flat, install the new hardware and torque to the precise specs following the shown sequence exactly. Use the NEW torque-turn specs, and make sure you use the PROPER procedure for your particular head bolts - there will be several listed in the head gasket installation instructions depending on which bolts are used. Also lube the bolt threads and under the flanges with engine oil, but not so much that the bolts hydraulically lock in the holes. Lube them well and let them drain off before installation. I've done more 40/50 head gaskets than I can count, and proper assembly is more than half the battle in keeping one together.
JDGnut
02-04-2004 13:11:31
They have a new head Gasket out for the 466... R80026... (Do not use the older style gaskets in the higher HP applictaions.. old part number was RE34010.. some dealers may still have these in stock.. and are good for most applications.. Except 4wds.. have them order the new part number if they do not have one..) Also Get the new flanged head bolts... While the head is off.. check the liner hight.. the standout should not be more than .005... Of course have the head surfaced checked... and look at the block for pitting where it is blowing out.. Hope this helps...
JDGnut
DON
02-06-2004 06:32:28
 Re: Re: 8450 HEAD GASKET in reply to JDGnut, 02-04-2004 13:11:31
THANKS FOR THE HELP. JUST THOUGHT I WOULD MENTION THE R80026 HAS BEEN SUBED AND THE NEW NO IS THE ONE I HAD IN THERE. CANT RECALL THE NO. AS I SLEPT LAST NIGHT. HA. DON
