JD 40 Remote Hydraulics Help
krk
09-01-2004 18:58:01
Need to find out how to hook up remote hydraulics on a JD 40 without using the factory option lever and valves. (Too difficult to find the factory option equipment). If anyone has done this please help.
Mike M
09-02-2004 06:03:28
 Re: JD 40 Remote Hydraulics Help in reply to krk, 09-01-2004 18:58:01
You will have to remove a section of the hyd. pressure line. I have seen this done some right between the dash and the rockshaft.You will need to run the pressure into your valve first, I think you will need a power beyond type valve,then from the power beyond port back to your rockshaft. The valve will have a separate return port this will have to go back into the resivor.You might have a hard time finding a fitting to fit that factory JD line end as JD used some wierd ends.
Hayfarmer
09-01-2004 21:50:49
My 430 has a #35 loader on it, dealer installed. The pressure line from the pump is interrupted just behind the dash. The line runs to my loader valve, the return from the valve goes to the rear toucho matic or whatever they called the 3 point on those. Don"t know why you couldn"t do the same with a remote valve. Just need an open center valve Think the 40 should hav similar plumbing.
Henry J
09-01-2004 19:41:23
krk
I know how to lash a loader into the existing hyd on a 420 - been there and done that.
Matter of fact, I am in the process of putting my 420 back together and will have a remote on it this time, and will have all the plumming, modern valve, valve mount, hoses, etc from the ole hook up laying in a heap.
my email is [email protected]
Ray
09-01-2004 19:09:27
I"ve got a remote valve for $600,the parts guys are asking around $800 for there"s.
krk
09-01-2004 19:21:48
 Re: JD 40 Remote Hydraulics Help in reply to Ray, 09-01-2004 19:09:27
There other problem is ($$). I am looking for function without going too expensive. I seen a 420 with a loader at an auction and it did not use the factory remote valve but used the valve on the loader frame but I did not see what is takes to tap into the hydraulic body under the seat. If anyone knows how to please help.
buickanddeere
09-02-2004 12:07:50
 Re: JD 40 Remote Hydraulics Help in reply to krk, 09-01-2004 19:21:48
Look around for a 1010 prior to serial number 42,000. Common as dirt and the hydraulics sell cheap. Most people don't realize it all bolts onto a 40,320,420,330,430,435,440 as well. By the time you purchase a valve,hoses,lines,fittings, quick connectors etc. The expense will be very close to a used factory system. Plus all the time to tinker it on there just to have a non factory system.
