Fred: Well, the AA 5724 R selector valve was generally viewed as an improvement. If you used the A 3613 R plugs, you had to remove them and replace with the dummy plugs everytime you wanted to switch back from the remote cylinder to rockshaft use. You also tended to lose a fair amount of oil in the process. Our "A" had them and it was always fithy on the back. The good news is that if you ever want to match original paint the Powr-Trol area is a good place to start since it was always covered with oil soaked grease and dirt. By installing the AA 5724 R selector valve in the upper hole and letting a dummy plug in the bottom, you can switch the flow of the oil from going to the rockshaft cylinder to the ports that are covered by the pipe plugs on the right side of the P-trol box. Typically, two short lengths of hydraulic hoes were installed onto machined Tees installed in those ports, the hoses were then wrapped around and under the battery box, where they exited on the left rear. There (originally) they were hooked to Aeroquip break away fittings, the kind that would separate if the plow you were pulling suddenly stopped and broke loose from the tractor hitch, as they were designed to do. Today, most folks terminate them with the modern "Pioneer" style fittings, or those that match their other tractors. I used Pioneer on my "45"W loader installation on my "70"D, and it works great. I personally recommend going the AA 5724 R way if you are going to need to switch back and forth from rockshaft (like if you have an 801 hitch) and the remote cylinder. Frank
