JD M 3 point hitch?
spurgon
09-01-2004 16:17:29
I just heard of an after market 3 point hitch for the John Deere M. Has anyone had any experience with one of these?
Thans,
james
Pat
09-02-2004 14:55:29
 Re: JD M 3 point hitch? in reply to spurgon, 09-01-2004 16:17:29
I have a Worksaver HK-201 three point adapter on my M. It works fine for about anything that doesn't need to tilt one way or the other like a finish mower or blade, but you can't put a plow on it. I'm satisfied. There is a limitation on how much load you can put on it, based (I think) on the way the upper link is mounted. It bolts on where the belt pully would go, and two of the bolts are not that large.
It bolts on, and if you wanted to you could restore the tractor to the original condition in maybe an hour. You don't have to cut, bend, or weld anything to make it work.
If you have any specific questions, I'd be glad to help.
Pat
Mike M
09-01-2004 18:30:15
Some M"s have a tool box under the seat and if you use a 3 pt. conversion that uses a top link that goes from the rear housing to the implement it will not lift up very high without bending up this tool box and maybe even seat frame. The MT tractor seat is up higher and does not hit. I made my own that"s more like a quick hitch and just has a short custom made top link from the adapter frame to the implement.
Joe
09-01-2004 17:45:48
Hello. No experience with the kits. I made one my self just like them for my MT. I have to say it worked as planned. But fact is the lift system on the hydraulics on the M's and MT's just can't take it. I had a pretty heavy built grader blade, with two railroad ties on it for weight. It was all the tractor wanted to lift. I know the lift is good due to lifting the mounted two bottom plow we have all the time. I just would get your hopes up of hauling a mower around on the back, unless it's a cheap light one. Joe
