JD 5520 pros/cons
David JD
09-01-2004 14:04:48
I'm thinking about purchasing a new/used JD 5520 with loader no cab for my small farm. The tractor is going to be used for everything under the sun from doing odd end jobs with the front loader to pulling equipment for about 35 acres of crops/and 10 acres of hay. I want to know if there is any red flags on this tractor. I would also like to know if any one has owned this tractor and there feed back on the tractor.
Thanks
farmer mike
09-03-2004 04:40:44
 Re: JD 5520 pros/cons in reply to David JD, 09-01-2004 14:04:48
If you have any hills, the 4WD is a blessing with a loader. The 2WD will be helpless backing up any grade with the loader. I second the opinion about going to the 6000 series. I have a 4WD 6110, and it is a great machine. I've heard about "problems" with the 5000 series, but can't be specific. Mike
leon
09-02-2004 05:19:53
This highest powered 5000 Series is quite a tractor for the money! For your 35 acres it should do very well. However, if you wanted to do a lot of very heavy tillage, like plowing or ripping for hundreds of hours per year, the 6000 Series might be a better choice. If you wanted to save a few bucks, you might consider the 5420. It's basically the same tractor with a bit less power, which you might never notice. I'd suggest you look for one with the synchronized transmission and MFWD. If you are going to do a lot of loader work, the synch reverser trany is nice. Also, if you're going to do lots of pto work, the 540E pto option is nice.
ALLAN/CA
09-03-2004 08:56:47
 Re: JD 5520 pros/cons in reply to leon, 09-02-2004 05:19:53
We have a 5510 4WD at work and it's been a great tractor. We have the 12 speed power reverser and its worked out well. I don't think you will have any problems even on heavy work on this tractor. When we ordered our tractor JD had stopped production to correct some problems with the first tractors off the line and ours has been okay.
