Conversion of 1937 Model A to Electric Start
Royce
09-01-2004 09:25:09
How do I need to proceed in converting a 1937 Model A JD to electric start? Would love to keep it as is, but geeting too old to continue starting by hand.
960
09-02-2004 17:56:46
 Re: Conversion of 1937 Model A to Electric Start in reply to Royce, 09-01-2004 09:25:09
You will need parts from a donor styled electric start A up to mid 47 model. The conversion is a bolt exchange process using JD parts. You need an electric start flywheel, crankcase cover with intregral starter bracket, top mount delco starter matching bracket, and starter ring gear cover band. I made a bracket and mounted a IH M battery box in front of the left rear axle. It is close to the starter for cables and not as evident. You could mount a delco 12V generator in side of right front frame using a JD bracket and pulley on fan shaft or skip generator and use battery charger periodically as mag will fire engine. Replace flywheel seal while flywheel is off an make sure you have endplay set correctly. I never understood why the correct police find fault with someone who wishes to enjoy their own tractor in a much physically safer manner.
Carl
09-02-2004 19:53:53
 Re: Conversion of 1937 Model A to Electric Start in reply to 960, 09-02-2004 17:56:46
No "correct police" here, Royce stated he would love to keep it as is and I made a suggestion, that"s all.
Carl
09-02-2004 19:52:54
No "correct police" here, Royce stated he would love to keep it as is and i made a suggestion, that"s all.
960
09-02-2004 20:10:58
 Re: Conversion of 1937 Model A to Electric Start in reply to Carl, 09-02-2004 19:52:54
Sorry for the mixup. Not directed to Carl at all but this subject has come up before anytime someone has wanted to electric start an unstyled. The next owner can unbolt the electrics and return to stock. As the baby boomer collectors age though electric start might suddenly be a good idea. Happy collecting.
Carl
09-02-2004 10:29:28
Perhaps you could build a remote starter using a small engine and pulley to turn the tractor engine over using the belt pulley and clutch. That way the tractor could remain original. The remote starter could be mounted on a small trailer or the bed of a pick up.
buickanddeere
09-03-2004 04:52:06
 Re: Conversion of 1937 Model A to Electric Start in reply to Carl, 09-02-2004 10:29:28
I'm all for avoiding butchered farmer fix tinker jobs. When looking at the risk and safety vs. origionality. I'm have to lean towards an all JD electric start conversion over the flapping belts. That said, I've seen old geezers at antique show that can hardly hobble around. That between wheezing from farmer's lung and missing a finger or two. They have the tractor well tuned & maintained. The pet cocks are opened, the engine eased over and with mostly just leaning thier weight against the flywheel. Then the tractor starts on the 1st or 2nd pull.
