Coolant leak 2510
jdman(MO)
08-31-2004 20:40:29
Today noticed steam around the exaust manifold, then saw coolant leaking from the left top where the head meets the block. Will a new head qasket do any good,or are talking about a resurface of the head and adding a spacer to the sleeve.? Russ
Mike M
09-01-2004 13:34:47
 Re: Coolant leak 2510 in reply to jdman(MO), 08-31-2004 20:40:29
You may want to try retorquing the head bolts first,it just may save a tear down if loose. Copercoat is made by Permatex.Most auto parts stores handle it. I don"t think that it is recommended from JD to put anything on a new gasket for those tractors.
Bob
08-31-2004 21:31:18
If you have an external water leak at the side of the head, rather than a leak of combustion products into the cooling system, I think there's a good chance cleaning up the head and the block and installing a new gasket will fix it.
Unless instructions with the new gasket say "no sealants", I would spray several coats of Copper Coat, or aluminum spray paint on both sides of the gasket, with drying time in between, before installing it.
Make sure the bolt holes in the block are clean all the way to the bottom of the threads, and that the threads are in good condition. Check the head bolts over for rust pitting, and replace, if necessary.
jdman(MO)
09-02-2004 05:32:59
 Re: Coolant leak 2510 in reply to Bob, 08-31-2004 21:31:18
Well yesterday checked coolant it was about 2 gallons low. Nothing in the oil, and no smoke in the exaust. Ran it for about an hour, with no external leaks. Heat indicator never moved off of cold. Suspect bad indicator, maybe bad thermostat, and or pressure cap. But where did all that coolant go? Going slow on this one.Russ
gus
09-01-2004 12:34:35
Bob,
What is "Copper Coat"? Does it have a brand name or is"Copper Coat" it?
Thanks
