60 wiring diagram
R-man
08-31-2004 20:07:05
I bought a new wiring harness for my 60. Tractor had all the wiring stripped off when I got it. I followed the meager instuctions the best I could but do not have any spark. If I run a wire from the battery to the coil it will run. Can someone provide a diagram? The serial number is 6054653. Thanks.
Clooney
09-01-2004 02:51:58
 Re: 60 wiring diagram in reply to R-man, 08-31-2004 20:07:05
R-man, you have a fairly early 60 so I E-Mailed you an early 60 wire print.. The Deere factory wire print covers multi tractor models & is more confusing than helpful on the early 60..
[email protected]
R-man
09-04-2004 02:00:01
 Re: 60 wiring diagram in reply to Clooney , 09-01-2004 02:51:58
Clooney, I do not mean to 2nd guess you but the way I calculate it my tractor was built 85 percent thru the total 60 series production run. Are you sure it needs the "early" wiring diagram? Thanks for the help. I really appreciate what you do for everyone on this forum.
