720d engine racing
Hilltopper
08-31-2004 19:22:40
My tractor engine seems to have no compression hold back when going down the slightest grade the motor races. The govenor works o.k. under load. The problem seems to be getting worse. Any ideas?
Clooney
09-01-2004 06:04:45
 Re: 720d engine racing in reply to Hilltopper, 08-31-2004 19:22:40
Hilltopper,
Most of my 2-cylinder diesels have fair engine braking when going down a slight hill but do over rev slightly when going down a steep long hill..
You could have a weak engine as Mike said or you could have a fuel rack setting problem or governor adjustment problem.. Or depending on the hill severity could be somewhat normal.
Does your engine shut down good when the lever is pulled & the throttle pulled all the way to the rear? IF SO, then next time you descend a hill try pulling the throttle to the stop position & seeing if the engine braking gets better.. If it does you probably have an idle speed, or fuel rack, or governor adjustment problem.. If the tractor still wants to run away you are either normal, or have low compression.
You might want to sniff the engine oil for signs of diesel fuel, if that engine oil is full of diesel fuel it could be getting sucked past the rings on over-run & burning & adding power on the decent..
[email protected]
buickanddeere
09-01-2004 05:58:04
The two cylinder Deeres engine braking on hills is about as effective as bicycle brakes on a truck. Possibly the fuel rack control linkage between the govenor and fuel rack is out of adjustment. There is an adjustment where the linkage makes the 90 degree turn. Follow the service manual closely for the serial number range of your tractor.
Mike M
09-01-2004 05:39:45
Those 2 cyl. diesels usually hold back on a hill better than the gas models due to thier high compression. You say it seems to have no compression and is getting worse,than it is time to get the compression back. New valves,seats,pistons,and rings,may be in order.Start saveing up lots of $$$
Carl
08-31-2004 22:55:52
The governor will not hold you back on a hill. The governors function is to hold a selected engine speed under load and to close the throttle approximately 10% above that selected speed. Once the governor closes the throttle, gravity and the weight of the tractor wiil continue to accelerate the tractor unless you apply the brakes. Gasoline engines hold back better than diesels on a hill because they are drawing a strong vaccuum against the closed throttle plate, diesels have no throttle plate and thus no vaccuum. The term "going down hill against compression" is actually incorrect as applied to a gas burner because the closed throttle plate allows hardly any air into the cylinders and thus very little compression, the vaccuum against the throttle plate is what is actually doing the engine braking. A diesel has lots of compression at all times but 90+ percent of the energy required to compress the charge is returned on expansion during the following down-stroke whether any fuel is injected or not. That"s the reason compression release type engine brakes like the "Jake Brake" were developed. When the compression is released at the top of the compression stroke, there is no energy returned on the following down-stroke resulting in a net negative energy at the flywheel and a strong braking effect.
CFWelles
09-02-2004 04:03:30
 Re: 720d engine racing in reply to Carl, 08-31-2004 22:55:52
Very good summary explainging engine braking effect from both engine types. Guess I better go over the brakes real well on my just purchased 730 diesel as I have a few fields on my PA property where the slope is fairly exciting. Guess I better learn to be more of a cross hill operator.
Soldier Tom
09-01-2004 10:46:00
Carl, So, if I pulled the decompression lever going down hill, would that, in effect, "jake brake" the tractor, or is that a different thing all together?
~Walk in peace~
Soldier Tom
Carl
09-02-2004 10:16:37
 Re: 720d engine racing in reply to Soldier Tom, 09-01-2004 10:46:00
Thanks to Clooney and Gus for the replies to Soldier Tom"s question before I could get back to the forum to answer. And thanks to all of you for an educational and entertaining forum. Carl
Clooney
09-01-2004 12:07:37
Soldier Tom, there a couple of types of Jacobs [Jake] brakes.. One is the exhaust valve lifting type that Carl spoke of..
On the standard exhaust valve type �Jake Brake� oil pressure usually moves a slave piston to momentarily open the exhaust valve(s) while the engine piston is at or near top dead center releasing the compressed cylinder air into the exhaust system.. That allows the engine compression to work as an engine brake but by releasing that compressed air at TDC it can�t add it�s compressed power back on the down stroke. That is the Rrr Rrr Rrr you hear when the Jake handle is pulled..
You can�t just pull your compression release as the would also remove the compression braking from BDC to TDC.. You need to make compression but then release it at TDC to get any effective engine braking.. Just pulling the compression release would simply allow the engine to freewheel & that would hurt any engine over-run braking..
Clooney
Soldier Tom
09-01-2004 12:41:29
 Re: 720d engine racing in reply to Clooney, 09-01-2004 12:07:37
I seeeee e, said the blind man.
Makes sence when you break it down to me. (Oh that was a bad pun, sorry, everyone). Thanks!!
~Walk in peace~
Soldier Tom
Mike M
09-01-2004 11:52:10
I think a jake brake keeps the valves shut or part of them from opening all the way up. If you pulled that decompression lever you would be in for a fast ride for sure.
Gus
09-01-2004 12:45:48
 Re: 720d engine racing in reply to Mike M, 09-01-2004 11:52:10
Mike,
A Jake works just like Carl said, the exhaust valve opens at the top of the compression stroke to release the compressed air. All the work used to compress the air is lost to the exhaust and this slows the truck. In other words, the engine is acting as an air compressor and absorbing energy instead of producing energy. It is one heck of a help and I don't like driving a big truck without one.
Mike M
09-01-2004 13:17:36
 Re: 720d engine racing in reply to Gus, 09-01-2004 12:45:48
I just got back from the Jacobs web site and got all straightened out on how they work.
Now could someone explain to me why a gas engine with multi port fuel injection doesn"t hold back a trailer on a hill as good as the old engines with a 4 bbl.carb. ? I"m wondering if it has something to due with the IAC letting more air past the throttle plate than a carb. ?
Clooney
09-01-2004 15:42:21
 Re: 720d engine racing in reply to Mike M, 09-01-2004 13:17:36
Mike, you ask..
Quote: "Now could someone explain to me why a gas engine with multi port fuel injection doesn�t hold back a trailer on a hill as good as the old engines with a 4 bbl.carb. ? I�m wondering if it has something to due with the IAC letting more air past the throttle plate than a carb.?"
--There are a few different reasons..
Probably first & foremost is the automatic transmissions used on the later vehicles.. Most just [free-wheel] in over-run while in high gear as that is a BIG fuel saver for higher MPG.. The torque converter stays locked up on most at higher speeds [even in over-run] so you don�t get as much trans friction loss either..
Next, is the trans & rear axle ratios used as the fuel injected engines usually have more low end torque..
Next, is a high concentration placed on reducing trans & engine friction so all you have left is engine vacuum..
Then, you have the newer camshaft profiles that lower the vacuum slightly on some over-run RPM ranges to increase fuel economy.
Then, there is this emission thing that doesn�t want to let the engine idle down at over-run so just removes some fuel & spark.. The IAC sort of follows the throttle position to act as a dashpot & to keep the engine running lean.. When the throttle is first dropped the IAC is still open a good amount & slowly steps down to a lower idle..
The newer computer controlled vehicles will give decent over-run braking but need to be brought down a gear or two to get the desired results..
Clooney
Mike M
09-01-2004 18:50:48
 Re: 720d engine racing in reply to Clooney , 09-01-2004 15:42:21
It sounds like it isn"t my imagination ! It also sounds like it is a combination of factors. I have the overdrive turned off when hauling and have also pulled the gear shift down still picks up speed faster than the old models. Isn"t that new allison behind the duramax set up for trans. braking ? If so it is probably a good idea.
Hilltopper
09-01-2004 05:58:24
Thanks for the explanation.
