D flywheel bolts
Chris
08-31-2004 14:46:26
I was wondering if any of you guys knew if the 3/4" x 6 1/2" bolts that hold the flywheel on a D were hardened or can I just get a set of grade 5 hex head bolts and stick on it? If not do you know where I can get a set of new "correct" bolts? I have tried John Deere and they found the size but told me they can't get them anymore and didn't know what kind of bolts that are used. Thanks for all of the help.
Clooney
09-01-2004 04:12:34
 Re: D flywheel bolts in reply to Chris, 08-31-2004 14:46:26
Chris, those factory bolts aren"t marked but from experience they are around a grade 3 or 5..
You can just use grade 8 standard hex head bolts but the heads won"t look original.. You will probably have to hold the heads from turning while tightening also..
If you look around [or try Correct Connection] you should be able to find some square head grade 5 or grade 8 bolts that will work..
If you use used flywheel bolts look at the threads carefully as a lot of original bolts are stretched at the threads..
[email protected]
Chris
09-01-2004 07:09:14
 Re: D flywheel bolts in reply to Clooney, 09-01-2004 04:12:34
Thanks alot Clooney. I will try and find some this afternoon. Just didn't want to use the old rusty ones and couldn't find a good description for new ones. Thanks again and have a nice day.
Glen in TX
09-01-2004 09:15:26
 Re: D flywheel bolts in reply to Chris, 09-01-2004 07:09:14
You might try mcmaster.com, MacMaster Carr Industrial. Can get small quantities of hard to find bolts from them.
ChrisfromSolitude
09-02-2004 12:11:11
 Re: D flywheel bolts in reply to Glen in TX, 09-01-2004 09:15:26
I found some at a local Bolt and nut store. I got the grade 8 with hard washers and big heavy nuts. Thanks to both of you guys for your help. Maybe I can get this beast back together this weekend and see if she will fire up. Have a nice day. Tried using Chris for my name but it said it's allready spoken for. I guess I'm Chrisfromsolitude now.
