Coolant leak on G
Matt B
08-31-2004 11:47:04
I have coolant slowly dripping from the vacinity of a bolt on the left side of the engine block, on the bottom where it bolts to the frame rail. My question is do the bolt holes in this area go into the water jacket, or should I be looking for a crack? It doesn"t look like it is leaking around the gasket at the back of the block.
Thanks,
Matt
G-MAN
08-31-2004 13:42:33
 Re: Coolant leak on G in reply to Matt B, 08-31-2004 11:47:04
No, I don't think those vertical bolts go into the coolant passages. And there is also no coolant exposed to the rear block/main-case gasket either, so you either have coolant leaking from the head-gasket or lower water pipe area and it's trailing back toward that area, or a crack somewhere.
