Frank, you ask... Quote: "This one appears to me cast, iron, right?" --Correct, those later DLTX carbs are cast iron.. Quote: "Is this common to find carbs broken in this manner?"
--Somewhat, over the years I have had to repair quite a few that were broken at the base flange. Not exactly sure why they broke to begin with but all were on tractors that were bought with broken carbs to begin with.. If the break is at the flange ears they are pretty easy to repair. I have brazed them but am not all that happy with the repair or it�s looks due to the difficulty in brazing in those tight corners.. The best thing I have found so far is to V grind the cracked areas & pre heat then TIG weld using a good cast type repair rod [Personally I like Vulcan �510-ci Cast TIG rod].. Once the repair is ground down & glass beaded & painted the repair usually can�t be seen.. Be sure to use a mill or large flat file & make the base flange perfectly flat when done.. As Duane said; If the break goes deep towards the carb body or into a fuel passage the repair gets very difficult & should then probably be sent to a professional repair shop. I have always repaired my own so have no idea what a professional repair would cost. Used carbs are getting pretty pricey but probably so is a good professional repair.. [email protected]
