Compression Ratio on 530 HI-Altitude Pistions
Tyler-MO
08-31-2004 06:08:19
I have a set of high altitude pistons(flat top) for a 520/530 JD tractor. I am wondering what compression ratio they will give me with a standard head/block surfacing. Any thoughts??
Mike M
08-31-2004 12:37:38
 Re: Compression Ratio on 530 HI-Altitude Pistions in reply to Tyler-MO, 08-31-2004 06:08:19
I don"t know what CR they are but you can still run them in lower altitudes. I had a 530 with them in it ran fine in Ohio. If you need pistons use them.
buickanddeere
08-31-2004 09:19:05
Any part numbers/name on those? They sound like LP pistons?
Tyler-MO
08-31-2004 09:29:26
 Re: Compression Ratio on 530 HI-Altitude Pistions in reply to buickanddeere, 08-31-2004 09:19:05
The number stamped on the top of the piston is B3848R. They are truely flat top pistons, not LP I can assure as they do not have any portion protruding from the face of the piston to go into the valve recess area of the head. Do you know the compression ratio of a factory JD high altitude piston??
Thanks
Tyler
