valve cover oil trough G
Ken C.
08-30-2004 19:27:57
I was cleaning the valve cover and noticed that there was only two oil holes, one on each end of the trough over the exhaust rockers, but not any over the two intake rockers. Is this right, if so how do the intake rockers get oiled. Any ideas, Ken. 52 G.
Clooney
08-31-2004 03:36:12
 Re: valve cover oil trough G in reply to Ken C., 08-30-2004 19:27:57
Ken C, you ask..
Quote: "noticed that there was only two oil holes, one on each end of the trough over the exhaust rockers, but not any over the two intake rockers. Is this right, if so how do the intake rockers get oiled"
--That is correct.. The old 2-cylinder Deere"s don"t use any valve seals so any excess oil dropped or sprayed on the intake valves will get sucked in & cause an oil burning problem.. The oil dropped on the exhaust valves is mainly for valve cooling anyhow.. Those intake valves don�t need much oil & the little they do need comes from oil mist inside the valve cover area.
[email protected]
Ken C.
08-31-2004 20:03:45
 Re: valve cover oil trough G in reply to Clooney, 08-31-2004 03:36:12
Thanks for the info Clooney, i feel better now about putting it back on, i was afraid those intakes were'nt getting enough oil, guess i should have known it works, been in there a lot of years and still works. Thanks again.
