JD 111 Axle
Thane
08-30-2004 09:35:33
I enjoy this site, getting lots of info for my 'A' and my 40. Now I have a problem with my smallest Deere. Last night I snapped the axle on my John Deere 111 lawn tractor. The right hand rear tire snapped off, right where the axle enters the differential. Does anyone know the cost and hassle of replacing the right hand side axle? Should I just look at junkyards for the entire rear-end? Thank you, Thane
leon
08-31-2004 05:20:04
 Re: JD 111 Axle in reply to Thane, 08-30-2004 09:35:33
The original rear axles in the Peerles (Tecumseh) transaxle on my old JD 111 just had flats on two sides of the axle where it went into the powdered metal differential gears. This kept splitting the gears. I'd suggest that if you want to fix it right and not have to go into it again, you get the newer style gears and axles that have splines rather than flats. Yep, as mentioned earlier. grease those axle bushings upon reassembly. If fact, I'd suggest youi put "too much" grease into the case. This way, as the grease ooses out around the axles over time the bushings will get grease.
Bob
08-30-2004 21:34:58
The axle shaft appears to be still available, $35 or $40, depending on which one you need. You need the transaxle tag number to order the shaft from Deere.
MarkA.
08-30-2004 11:30:51
That was a pretty common problem with the 111. That axle just runs in a bronze bushing. Transmission only has gun grease for lube. It was cheaper years ago to buy a new transmission. But now would probably cost more than the tractor is worth. Look for a used one. Then split the tranny and grease those bushings before assembly.
