4010 rockshaft
kwgray
08-30-2004 06:17:09
I have a 4010 with a rockshaft that after sitting for a day the power steering works very hard when started and the rockshaft is slow too respond and chatters when it first comes up. After running for a minute everything operates fine. when I shut it down the rockshaft settles back to the down position even though the control lever is in the up position. I do have a leak in the steering motor which I believe would result in the steering problem but would this also affect the rockshaft? Thanks.
Gerald J.
08-30-2004 08:31:19
 Re: 4010 rockshaft in reply to kwgray, 08-30-2004 06:17:09
Its all one hydraulic system. Loss of pressure or pump prime kills everything.
Sounds like it needs a check valve in the transmission. There's a service information on converting an elbow outside to that check valve. I had that problem on my '68 4020 which I fixed.
I've posted some information on that repair on my web page.
Gerald J.
