60 Radiator Overflow?-what is this?
Fred from MO
08-30-2004 02:36:25
On the top front side of my radiator there is a pipe plug fitting, just below the neck. It appears to be an overflow,it threaded however mine does not have any kind of plug in it. Is this supposed to be plugged with a pipe plug, or left open such as to relieve pressure when the radiator heats up. I would think that you would get a lot of dirt in there with the plug out of it. I may be missing a piece to the radiator? Does anyone know what this is or what should go there?
Ben.So.Tex
08-30-2004 11:25:32
 Re: 60 Radiator Overflow?-what is this? in reply to Fred from MO, 08-30-2004 02:36:25
Fred. I fix the one on my B got a copper 90 deg fitting and screw it into the rad and then put a piece of copper tubing on the 90 deg and ran it out the bottom of the tractor casting so it will drain on the ground. Works great for me Cost about 7 dollar. Good luck Ben
F-I-T
08-30-2004 05:58:27
third party image
Fred:
I think you might be missing the pipe that diverts the overflow down the front of the radiator and out the bottom pan.
Frank-in-Tallahassee
70D // 855 // VAC // IHC �Cub�
[email protected]
Fred from MO
08-30-2004 16:47:47
 Re: 60 Radiator Overflow?-what is this? in reply to F-I-T, 08-30-2004 05:58:27
By golly Frank you are correct!
Thanks for the picture. Does the diagram give the fitting size that goes into the radiator? It would save me a trip to the tractor before I head to the hardware store.
F-I-T
08-30-2004 18:42:41
 Re: 60 Radiator Overflow?-what is this? in reply to Fred from MO, 08-30-2004 16:47:47
Fred:
Well, they both show as good part numbers through JDPArts.com.
#8 is B 60 R, "Packing - Rubber" measuring ID .469", OD .688", and the thickness is .375". Price is $2.02. Looks like you could cut a slice off of a nice piece of rubber hose and make one.
#9 is C 1705 R , "Gland" has no dimensions listed, and is priced at $9.74
Sorry I couldn"t offer more info.
Frank
