4020 rockshaft dont work
DT
08-29-2004 20:32:23
I have a friend that just relaced a hyd line on the right side of his 4020. After doing so and filling the trans back up he claims steering, scv's, and brakes work, but the rockshaft wont. He moved the draft to both positions and no luck. He said he unhooked the linkage and the lever going into the housing, for the up and down moves very easily. Is there a roll pin inside of the valve housing? Im just tring to get some ideas before I look at it tomarrow. He says it worked before the line broke, but this may be a coincidence? Thanks, as always!!
david val
08-30-2004 02:53:40
 Re: 4020 rockshaft dont work in reply to DT, 08-29-2004 20:32:23
the replcement line is probably a very old stock and maybe plugged. in the old models this line fed only the rockshaft so it's the main culprit. even if the pipe and the rear elbow are not plugged now, impurities from may have entered the valves creating malfunction.
david
