Electric ignition on JD 50
Markie
08-29-2004 18:47:13
I want to get rid of points on my 50 and go to the electronic ignition for the time being....who sells the best kit and are there any tips etc on how best to do this?
Thanks, mark
John Van Valkenburgh
08-29-2004 21:49:15
 Re: Electric ignition on JD 50 in reply to Markie, 08-29-2004 18:47:13
Mark,
I changed my 50 over to an electronic ignition system from Genesee Products. I bought the high output ignition coil from them as well. If you go that route BE SURE to tell them if you are using the stock positive ground or if you changed over to negative ground.
I"ve been very happy with my system. I can tell you from sad experience that it gives one heck of a zap...
Lots of units out there. Have not heard anything really negative about any of them. Overall I think the electronic ignition is a good thing to have, if for no other reason it eliminates any reduction in performance from normal wear to the points and condensor.
Best of luck,
John 1953 model 50
buickanddeere
08-29-2004 20:36:44
If ordering get the Pertronics 12V 3.0ohm coil if not installing a ballast resistor. For low rpm applications pertronics recommended the 32,000V industrial coil for a little more current across the plug gap.
John T
08-29-2004 19:35:08
Mark, here are a couple sources of elec ignition for your tractor.
Link
Link
While the stock coil will still give some advantage due to the faster and more positive switching of the elec switch over mechanical points, I STRONGLY SUGGEST to get the most bang for the buck and performance that can be gained from the use of a solid state switch THAT YOU COUPLE IT WITH A HIGH ENERGY HIGH PERFORMANCE COIL.
IMPORTANT Be sure n check with the switch vendor for coil matching (so it dont draw more current than switch is rated for) to the switch and also for plug wire recommendations (at higher voltages you need good wires and some vendors may use resistive wires). IMPORTANT You also have to match your tractors polarity (it was originally Positive ground) with the new elec unit you purchase.
Often (check with vendor) one runs a slightly wider plug gap when using an elec switch and high energy coil.
Be sure n check with the vendor to match the switch, coil, n plug wires.
Good Luck n God Bless ya
John T Nordhoff
Mike M
08-29-2004 19:03:43
I can"t understand why everyone is changing over to electronic ignition. I have seen a lot of follow up posts after they have and the tractor still won"t run. Maybe I"m just too cheap. A set of points and cond. and rotor is only $10.00 or less and the two tractors I use have lasted at least 10 years so far still fine. Maybe I"m doing something wrong ?
gus
08-31-2004 18:36:14
 Re: Electric ignition on JD 50 in reply to Mike M, 08-29-2004 19:03:43
Mike,
I agree. Electronic ignition is great on cars that have a bunch of electronics and computers anyway, one more won't hurt. But on a simple JD why complicate things with electronics? My beef with solid state is that it is so easily blown if exposed to the slightest overvoltage and when it quits it quits, there is no limping home with a makeshift repair...it is through. It won't tolerate much additional resistance either. There is no warning whatsoever before it quits.
Why pay a bunch of $$$ for all that. These tractors are so inefficient anyway that this isn't going to improve things very much.
